2025-09-21 16:53:57
4.8k
581
Calibration Cube Kobra S1
@Flavia_1779827
Calibration Cube (X, Y, Z) for 3D Printing
This simple yet essential calibration cube is designed to help you fine-tune your 3D printer’s dimensional accuracy. The cube is clearly labeled with X, Y, and Z axes for easy orientation, making it perfect for checking scaling, alignment, and extrusion settings.
Key uses:
  • Verify print dimensions against the 20 mm reference size
  • Identify axis-related deviations (X/Y shrinkage, Z height errors)
  • Test layer consistency and extrusion accuracy
  • Ideal for printer setup, tuning, and troubleshooting
Whether you’re dialing in a new machine or double-checking after maintenance, this calibration cube is a quick and reliable tool to ensure your printer is performing at its best.
calibration
cube
calibracao
cubo
kobra s1
kobras1
ks1
S1C
