2026-07-04 06:54:48
1.3k
124
Call of Duty Zombies Ray Gun Replica
@dharian_5531540
"Fetch me their souls!" — Bring the ultimate Zombies survival weapon to the real world!
This is a highly detailed, 3D-printable replica of the legendary Ray Gun from the Call of Duty: Black Ops Zombies mode. From the retro-futuristic barrel fins to the classic gauge on the back and the sleek grip, this model captures all the nostalgic energy of the mystery box's most prized possession.
This model has been specifically optimized for single-color printing. You don't need a multi-material system or automated filament changers to get a stunning result. The surface geometry features deep, pronounced panel lines and crisp mechanical details that rely on natural shadows to pop. It has been tolerance-tested to slice and print beautifully on Anycubic FDM hardware (like the Kobra, Vyper, or Mega series), minimizing stringing and ensuring high-quality overhangs.
Model Features
  • Single-Color Optimized: Designed to look amazing right off the print bed using a single filament. Every detail is physically extruded or recessed to maximize contrast.
  • Anycubic Slicer Calibrated: Optimized to prevent standard FDM printing issues like aggressive stringing or bed detachment on standard Anycubic extruder setups.
  • Perfect Cosplay Prop or Desk Toy: Scaled beautifully to serve as an eye-catching display piece for your gaming setup or a lightweight prop for cosplay.
Recommended Print Settings
  • Layer Height: 0.12mm to 0.16mm is highly recommended to cleanly resolve the thin barrel fins, gauge details, and the smooth curves of the grip.
  • Infill: 15% (Gyroid or Grid provides excellent internal strength without adding unnecessary weight).
  • Supports: Yes, supports are required for the lower handle curve, the trigger guard, and the front barrel overhangs. Tree/Organic supports in your preferred slicer (Anycubic Next, Cura, or PrusaSlicer) work best for clean, effortless removal.
  • Brim: A 5mm outer brim is recommended if you print the main body split vertically, ensuring maximum stability as the printer builds upward.
CallOfDuty
BlackOps
RayGun
WonderWeapon
Zombies
CoDZombies
Anycubic
Replica
Cosplay
Gaming
Gamer
Weapon
RailGun
Model
DeskToy
Collectible
