Code: YBTDSUWAFQ
🎨 HUEFORGE INFO🎨
🎯 Ready-to-print 3MF included
All settings are already configured. Just slice and print.
🌈 FILAMENT COLORS USED
#000000 PLA Anycubic Black Transmission Distance: 0.1
#606783 PLA+ Esun Gray Transmission Distance: 2.8
#ffffff PLA Anycubic White Warm Transmission Distance: 6.2
#e0e721 PLA Anycubic Yellow Transmission Distance: 5.8
This print uses 4 unique filaments
🔄 COLOR SWAP LAYERS
Start with Black
At layer #9 (0.8mm) swap to Gray
At layer #11 (0.96mm) swap to White Warm
At layer #19 (1.6mm) swap to Black
At layer #20 (1.68mm) swap to Yellow for the rest.
⚠️ IMPORTANT⚠️
• You can resize X/Y freely
• ❗ DO NOT change Z height
👉 If you scale the model, restore the original Z height
otherwise color transitions will be incorrect.
