2026-09-12 17:02:29
277
12
Chair Leg Cap
@schuetzi99_4394914
This chair leg cap is designed for chair legs made of 16 mm round steel tubing. Its unique design feature is that the load is distributed across a 24 mm washer, preventing the steel tubing from cutting through the plastic. The tubing rests directly on this washer.
You’ll need one 8.4 x 24, 2 mm-thick washer for each leg. This washer is inserted during printing. To do this, you’ll need to insert a pause in the slicer before printing the top layer.
I recommend 6 shells and 100% infill. I used PETG.
chair
leg
legcap
cap
