2025-03-29 04:39:14
24.6k
2k
Chess Voyage
@ERAVIA_3338673
CHESS VOYAGE
Modern Take on Chess That Blends Aesthetics With Functionality
Smooth Folding Mechanism Ensures Quick Setup and Effortless Storage Anytime
Travel-Friendly Design, with Available Embedded Magnet Versions for Improved Stability
Includes a Braille Version as Well
What is “Braille Chess” version?
Braille chess is a specially adapted version of chess designed for visually impaired players. It follows standard chess rules but includes specific modifications to make the board and pieces identifiable through touch:
  • Board Navigation: Dark squares are elevated approximately 4mm higher than light squares, providing a clear tactile distinction for easy identification.
  • Piece Recognition: Each chess piece retains its standard design, similar to the Staunton shape, ensuring players can easily differentiate them.
  • Side Distinction: Dark pieces feature slight spikes on top, allowing them to be distinguished from light pieces.
  • Piece Stability: A peg-and-hole system is used, where each chess piece has a small peg at the bottom that fits into holes on the board, preventing accidental movement.
CHESS VOYAGE FEATURES TWO NEW PIECE DESIGNS
for standard and magnet versions only
Print Instructions & Recommendations
  • It is highly recommended to clean the build plate with warm water and soap prior to printing to eliminate the potential adhesion problems.
  • Support is only required for the pieces in the Braille version. Every other part of the model should be printed without supports.
Assembly Instructions
  • Assembly requires no additional tools, materials or post-processing for standard versions. It is a simple print and play model.
  • Braille version would only require the removal of the supports for the chess pieces.
  • For embedded magnet versions:
  • Each print profile includes 8 plates. Caps and checker pieces do not have magnet slots and should be printed in all cases. The remaining 6 plates are for the board and pieces, designed for two magnet sizes: 8x2mm and 6x2mm. To ensure compatibility, select and print only two plates, one for the board and one for the pieces, that match your chosen magnet size.
  • During printing, the profile will pause automatically at the designated layer, allowing you to insert the magnets before resuming. If your nozzle is magnetic, it may pull the magnets out of the slots when printing continues. To prevent this, apply a small amount of glue before resuming to secure the magnets in place.
  • Note: Due to Makeronline's 100-file upload limit, the STLs for the 6x2mm magnet size could not be included. However, they are available through the 3MF files provided in the print profiles.
Model Information
  • Dimensions (X-Y-Z) | Large ~ Board: 235 x 235 x 12.3 mm
  • Dimensions (X-Y-Z) | Large ~ Modern Chess Pieces: 17.9 x 17~22 x 33~55 mm
  • Dimensions (X-Y-Z) | Large ~ Classic Chess Pieces: 18~21 x 17~24 x 32~65 mm
  • Dimensions (X-Y-Z) | Large ~ Checker Pieces: 20.7 x 20.7 x 5.2 mm
  • Dimensions (X-Y-Z) | Standard ~ Board: 200 x 200 x 10.5 mm
  • Dimensions (X-Y-Z) | Standard ~ Modern Chess Pieces: 15.2 x 14~19 x 28~47 mm
  • Dimensions (X-Y-Z) | Standard ~ Classic Chess Pieces: 15~18 x 14~21 x 27~55 mm
  • Dimensions (X-Y-Z) | Standard ~ Checker Pieces: 16.9 x 16.9 x 4.2 mm
  • Dimensions (X-Y-Z) | Mini ~ Board: 160 x 160 x 8.4 mm
  • Dimensions (X-Y-Z) | Mini ~ Modern Chess Pieces: 12.2 x 11~15 x 22~38 mm
  • Dimensions (X-Y-Z) | Mini ~ Classic Chess Pieces: 12~15 x 11~17 x 21~45 mm
  • Dimensions (X-Y-Z) | Mini ~ Checker Pieces: 14.1 x 14.1 x 3.5 mm
  • Dimensions (X-Y-Z) | Braille ~ Board: 200 x 200 x 17 mm
  • Dimensions (X-Y-Z) | Braille ~ Classic Chess Pieces: 15~18 x 14~21 x 33~61 mm
  • Commercial Use: Terms and conditions are available on Patreon.
Interested more in board games?
Backgammon Voyage
chess
braille
portable
foldable
travel
board game
chess set
braille chess
portable chess
foldable chess
travel chess
