2026-10-25 23:22:18
69
Chibi Grim Reaper – Hourglass of Life
@drakeforge3d_5567152
Every life begins with a full hourglass… and this little reaper is keeping count.
This chibi Grim Reaper holds the Hourglass of Life in skeletal hands, watching over the passing sands. An oversized pointed hood frames a sinister skull, while deep robe folds and small bony feet give the figure its distinctive mix of spooky charm and dark fantasy.
The tilted hourglass adds a storytelling touch, making this miniature keeper of time a striking addition to a Halloween shelf, desk, or gothic collection.
Display it in a single colour to highlight the sculpted details, or paint the robe, skull, and hourglass to create your own interpretation of Death’s little guardian.
Designed for FDM printing with supports.
   Guide
1. DRY THE FILAMENT
  • Recommendations:
chibi
toy
cute
spooky
creepy
skeleton
skull
halloween
halloween decor
grim reaper
