2025-02-13 01:28:34
3.4k
173
Chocolate Truffle Keyboard Switch Fidget
@vkobz_1020444
My favorite Valentine's day treat!
Part of my collection of keyboard switch fidgets
This clicker requires a mechanical keyboard switch (I have successfully tested Kailh navy box switches and other switches with cross stems).
Assembly does not require glue - just insert the base of the switch into the truffle ("top"), and push the liner ("bottom") piece on like a keycap. It should be tight, but if it does not fit, try setting the x-y hole compensation (or the equivalent in your slicer) to 0.2mm.
All color changes can be done by pausing at a layer height. No supports needed.
Recommended print settings:
4 walls
0% infill
adaptive layer height
thick bridges
infill wall overlap 20%
ferrero
rocher
fidget
clicker
keyboard switch
chocolate
truffle
valentine
gift
candy
