Christmas Tree Coaster
- The perfect functional gift for this holiday season!
- Finally a tree your cat won't destroy (hopefully).
- Scroll down for assembly instructions.
If you would like to sell our designs (or simply support us), please join our commercial license at Patreon. <3
https://www.patreon.com/c/Jefflynn
1. Twist the ring open. Insert 6 leaves per ring. For the topmost coaster, 5 leaves per ring is recommended. They are designed to be tight; some twisting around of the leaves will be needed.
2. You may glue the ends of the ring for security.
3. Space out the leaves evenly. Repeat this several times to make the desired number of coasters (3 to 5 recommended).
4. When placing the leaves into the trunk, make sure they stay flat (parallel to the ground).
5. Once the leaves are at the desired height, bend the leaves downwards. This will allow the coaster to stay in place.
6. Finally, place the star!
