Build your own little rocket straight from the kit card!
Simply remove the individual parts from the cards and assemble them to create the finished rocket. Thanks to the multipart design, you can easily combine different filament colors and create your own color scheme — no color-changing system required.
Once assembled, the rocket stands on its own and makes a great little decoration for a desk, shelf, or 3D printing collection.
Please note:
Due to normal printing tolerances, the fit of individual parts may vary slightly. For a secure and permanent fit, I recommend using a small amount of glue during assembly.
Important assembly note:
After printing, completely remove the tree support structure inside the main rocket body. Once the support has been removed, the rectangular connector block can be inserted into the opening.
Features:
- 🚀 Classic rocket shape in a charming kit-card design
- 🧩 Simply remove the parts, assemble them, and build your rocket
- 🎨 Perfect for custom color combinations with different filaments
- 🖨️ No color-changing system required
- ✨ Quick and easy to print
- 🪐 A fun decorative piece for your desk or shelf once assembled
- 🔧 Multipart design for a small model-building experience
