2026-10-25 17:51:48
30
ComfortCarry - Ergonomic Grocery Bag Handle
@Trisztan_4700665
Carry shopping bags with a broad, shaped grip that spreads the pressure from thin bag handles across your hand. The open curved hook makes it easy to load and remove bag loops.
This is a single-piece print with no assembly or extra hardware required. Slip the bag handles through the hook opening, settle them on the lower curved section and hold the main grip as shown in the photos.
Recommended starting settings: PLA, 0.20 mm layers, 3 walls and 40% gyroid infill. Use tree supports and an outer brim in the supplied orientation. Let the print cool before removing the supports and brim.
Check the carrier for damage before each use and increase the carried weight gradually. Strength depends on the filament, print quality and loading; no maximum load rating is specified.
shopping bag carrier
ergonomic handle
grocery bags
household tool
