2026-10-20 03:41:54
152
Crab king crown
@TheMatterBureau_3869887
Perfect for Halloween, costume parties, photoshoots, festivals and alternative fashion.
Sizing reference:
  • Head width: 14 cm
This is my personal head measurement for reference; fit may vary depending on your facial proportions and the specific design.
Adjusting the Fit with Heat:
If you need to adapt the mask to your face shape, you can carefully reshape the plastic using a hairdryer:
  3. Once the plastic becomes bendy but is not melting, carefully reshape it.
  4. Hold the new shape until it cools and hardens.
Heat warning: Heated plastic can cause burns. Never touch hot areas directly or put on a warm mask. Avoid overheating, work in a well-ventilated area, and check your filament's heat resistance before reshaping.
Repairing Broken Parts:
crown
crab
sea creature
tiara
halloween prop
