2026-09-22 04:42:11
1.1k
49
Creality SpacePi XL Top Mount for Kobra X
@rrmccabe_2417403
This is a premium upgrade system for the Kobra X that allows you to top-mount the Creality SpacePi XL
Countless hours went into designing this system to achieve the most OEM-looking fit and finish possible. This is an advanced kit for those wanting a professional looking design.
Every component was engineered for strength and stability, eliminating the sagging commonly seen in other designs. The system also includes print files with built-in pause commands, allowing you to insert nuts during printing for cleaner, stronger, and more professional assemblies. You can print in PLA or PETG but PLA is more than adequate.
3KG SPOOLS We have an option to run 3kg. spools. You remove the upper spool mount. Download the 3KG Spool Extender which includes a shaft extender, center sleeve and support. Use the support to set the spool mount height. See 3kg add-on here
Customize the top Caps to meet your needs. Accessories, Ace 2 Filament Hub, etc. All 18 versions available here
A few of the accessories in our FREE accessory kit fit this model. You can check out the accessory kit here.
The documentation clearly explains which parts to print depending on your intended setup. Only two parts require minimal supports, while the remaining components were carefully designed for optimal print quality without supports.
NOTE: The shelves are large prints that cover most your build plate. I have designed in provisions to help warping but you need to do your part too. Wash your plates with dish soap and hot water before printing both shelves.
The system requires:
Aluminum square tubing
Fastener Kit
Optional PTFE connectors
Rubber feet
Note we have found that Anycubic "light grey" is a really good match for the printer plastic. We use "texture grey" as an accent color on most our products.
Amazon links
The aluminum tubing is inexpensive, pre-cut, and readily available on Amazon. Full hardware details and assembly instructions are included in the documentation.
As mentioned earlier, there are easier solutions available. But if you want a system with excellent fit, premium finish, and OEM-style appearance, the Kobra Xs system delivers exactly that.
See Documentation below
REMIXING is NOT allowed
— Certified by the highly respected dumpster engineering division of Raccoon Engineering. Four tiny raccoon thumbs up. 🦝
Raccoon Engineering Website Link
Kobra X
Creality SpacePi XL
Raccoon Engineering
PDF
SpacePi XL Documentation.pdf
265.26KB
