2025-04-17 16:58:41
43.1k
5.3k
Cup Holders for Sofa Cushions
@Kickass3DPrints_1980536
No side table? No problem! These 3D printed cup holders slide snugly between your couch cushions to give you a place to hold your drinks, snacks, or even your phone. Choose from single-piece or twist-together versions in two cup sizes, perfect for either side or center setups on your sofa or armchair.
Support me on Patreon to access exclusive STL releases every month and help keep new designs coming!
⭐ Perfect for:
✅ Holding cans, cups, bottles, snacks, or remotes
✅ Small-space setups with no room for coffee tables
✅ Creating a center console between couch cushions
✅ Remote or phone storage while you chill
📦 Model Types & What's Included:
- 73mm cup holders, which fits most store-bought drinks and 85mm for larger cups and glasses
- Side model slides between cushion and armrest. Can be doubled up between cushions with optional 8x3mm magnets for extra stability when using two
- Two-part versions that twist together. No supports needed.
- Simplified print-ready versions. Requires supports and prints upside-down.
- Base options with standard 5in fins that fit most couches. Also includes 4in (shallow cushions) and 6in (deep/plush sofas)
🧠 Tips and Notes:
⚠️ Cold drinks only – not recommended for hot drinks!
⚠️ Soft cushions may cause movement when sitting/getting up. Be sure to test stability before use.
💡 Side holders are more stable than center holders
💡 5in models should be fine for most couches. Use a ruler to measure depth if unsure
💡 When using magnetic versions, double-check polarity placement
🤑 Want to sell this design? Check out the Commercial License membership on my Patreon.
By downloading this model, you agree to use it responsibly. The creator is not liable for any injuries or damages resulting from its use.
beer
can
cans
bottle
bottles
coaster
cup holder
soda
cushion
lounge
home
couch
phone holder
drink
drinks
holder
chair
armchair
cup
cups
