2024-10-10 17:58:11
6k
473
Cute Bear Piggy Bank
@Square3D_5249904
I had to print this little cute Bear Piggy Bank and i have to say, i am really impressed. Fits Euro Coins perfect!
No hardware needed, all parts printed and retrofited to only 4 colors perfectly. No need for AMS, every plate has 1 color or print by object/color. Only need glue! Keep reading carefully please!
This is a remix. I have modified some parameters in parts of the model that were too lose or too tight in some parts and wouldn't fit or would not hold together when joined. I printed several iterations until i got a perfect result as can be seen in the pictures. Also corrected rotation and small size increments so it can be tight but not too tight.
All the plates are ready with all settings ready to print, with all the colors assigned already. There are 4 plates and they are named for the corresponding parts and colors. Use the included profile for correct supports, clearances and ready to print!
Every plate has their own settings as well supports for each of them. Some plates have parts in “print by object” and that way you don't need AMS. The other plates have their own support type that should come out easily without tools.
Again, don't modify the profile or it won't print as it should! Use the included profile and change only the colors you want!
Instructions from the creator in the following video:
Creator:
Thanks to Jwoong that came with the idea and the creation of this model!
You can find this model here!
License and Attribuition:
Published, shared and given the according attribution respecting the original license, as per original model (CC-BY-NC-SA 4.0)
I do not own this model in any way or make any money from it. Respect the creators so they can model more like this!
cute
bear
piggy
piggybank
piggy bank
coin
coin vault
vault
eating
money
box
storage
mealheiro
geld
money bank
