2026-03-30 05:25:52
5.5k
288
Cute Kawai Cat House - Fullsize Pet Home
@TheLightning_2558699
A cute house in shape of a cute Kawai cat. The house is assembled via hex pins and dual compund resin (dont try to use superglue, you will have a bad time... ask me how I know)
The whole thing comes in 3 profiles:
The Base
The Walls
The Roof
Print them in that order and remember to mark off each plate once you print it, so you dont waste time.
My advice is to assemble the base and leave it to cure overnight. Then assemble the walls, a little resin glue and tape them together; insert the whole thing on to the base.
Same thing with the level two walls.
Finally, the roof assembly goes on top. there are no guide pins here, it was designed so the roof can be removed during hot summer months.
Detailed instructions are on the way, but before i do the whole guide; a couple of tips:
When applying resin, apply it to the inner edge, so when you press them together it will leak only on the inside of the house. An alcohol wipe down will clean it just fine.
If you apply it to the center, it will leak outside and ruin the finish. Use a fastener, tape or carpentry vices to hold the pieces together while curing.
cat
dog
house
cute
kawai
toons
tyle
woven
crochet
assemble
huge
big
scalable
full size
pet
home
