2026-10-22 11:51:37
66
Cyclohexane 3D Molecular Model — CAS 110-82-7
@MolGod_5546829
Cyclohexane (C6H12, CAS 110-82-7) — a free educational 3D molecular model for teachers and students, by MolGod.org. Each atom is labelled with its own engraved element symbol: no colour chart needed.
Which rings can the class see in Cyclohexane? The answer is one 6-membered ring, joined up by 18 bonds altogether (all of them single). Use the engraved letters like a register: call out each element and tick it off until the class reaches 6 C + 12 H (18 atoms altogether). Plan it into a unit on cycloalkanes (saturated carbon rings) and tetrahedral (sp3) carbon. Ask the class why this molecule cannot hydrogen-bond to itself: the computed count of donors and acceptors is zero. Fully sp3 carbon framework: a straightforward model for tetrahedral geometry.
MolGod.org offers this engraved model free to anyone teaching or learning chemistry. Teachers: use the model for an exit-ticket question on the structure the class has just studied.
Full record and more free models: https://molgod.org/molecule/110-82-7/?utm_source=printables&utm_medium=referral&utm_campaign=edu-3d-models
Licence & provenance: https://molgod.org/licenses/stl/110-82-7/
Same file on Wikimedia Commons: https://commons.wikimedia.org/wiki/File:Cyclohexane-3D-molecular-model-engraved-CAS-110-82-7.stl
A ball-and-stick model of Cyclohexane with each element symbol recessed into its atom sphere, generated by MolGod.org from a PubChem-computed 3D conformer (not an experimental crystal structure); atomic coordinates and connectivity are unchanged. STL mesh: 188,176 triangles, closed (watertight) single solid. Coordinates in ångström (STL stores no unit) — scale the model deliberately in your slicer.
Names in other languages: Cyclohexan (de); cicloesano (it); cyclohexaan (nl); cykloheksan (pl); 环己烷 (zh).
Chemical identity
Required attribution (CC BY-SA 4.0): "Cyclohexane 3D model by MolGod.org — https://molgod.org/molecule/110-82-7/ — CC BY-SA 4.0"
Licence text: https://creativecommons.org/licenses/by-sa/4.0/
education
teaching
stem
chemistry
stl
classroom
molecule
engraved
molecularmodel
cycloalkane
hydrocarbon
cyclohexane
chemistryeducation
molgod
c6h12
cyclohexan
