2025-07-22 04:51:03
1k
20
Daylite - Open Source Weather Display
@shivamhegadi_1438524
Daylite ESP32 Weather Display: Your Instant Weather Companion
Never step out unprepared again! Daylite delivers real-time forecasts at a glance with a sleek, minimalist design. Perfect for your desk, kitchen, or bedside, it’s the effortless way to stay ahead of the elements—rain or shine.
Why You Will Love Daylite
✅ 5-Minute Setup – No tools, wiring, or soldering!
✅ Budget-Friendly – Build for under $20 with widely available parts.
✅ Open Source & Free – Customize freely or contribute to the code.
✅ Beginner-Friendly – Ideal intro to ESP32, 3D printing, and IoT projects.
✅ Plug & Play – Powered via USB-C/micro-USB.
Parts List
  • ESP32-2432S028R Board – 2.8" ILI9341 display (240x320 TFT LCD).
  • Buy: Amazon US | AliExpress
  • Note: Ensure model ESP32-2432S028R ILI9341 2.8" – clones work if specs match!
  • Angled USB Adapter (90°):
  • USB-C or Micro-USB (match your board’s port):
  • Amazon US | UK
  • USB Power Cable – Any standard 5V adapter (e.g., phone charger).
Setup in 3 Simple Steps
Step 1: Flash the Firmware
Step 2: Assemble the Hardware
  • Attach the angled USB adapter to the board (facing away from the screen).
  • Insert the board into the 3D-printed case (display facing front).
  • Snap the back cover closed.
Step 3: Power & Customize
  • Plug in USB power – it initially displays a blank screen.
  • Connect to WeatherBoxAP on your phone or laptop.
  • Connect to your home WiFi from the portal. (if portal does not show up, go to http://192.168.4.1/ )
  • Swipe down from the top to open menu. From there, you can choose your location, adjust brightness, enable dark mode, and much more.
Key Features
  • 🌦️ Local Forecasts – Pulls data from global weather APIs
  • 🖍️ Clean UI – Sleek UI with Light and Dark Mode
  • ⏰ Night Mode – Automatically Dims the Screen during the night.
  • 🔄 One-Click Updates – Web installer handles all firmware upgrades
  • ⚡ Low-Power Draw – Draws <0.5W.
FAQs
Q: What does Daylite access on WiFi?
A: Daylite only connects to the OpenMeteo Weather API. No tracking, accounts, or data logging. You can View source code to verify.
Q: Can I modify the design?
A: Yes! All 3D models and code are in the files!. Resize or remix!
Q: What if my board has a different pin layout?
A: Leave a comment down below and I will give you files with a pin layout customized to your board.
Q: Does it work without constant internet?
A: Yes! Shows cached data, however, it updates the weather every 15 minutes.
Like This Project?
Give it a like and share it with your maker friends!
Get Building Now:
🔧 GitHub Repository | 🔧 Installer
Crafted with ❤️ by Shivam Hegadi
weather
display
esp32
benchy
makeronline
anycubic kobra 3
kobra 3
outside
beach
travel
home
desk
contest
household
decor
