Tired of messy cleanup every time you mount a shelf or hang a picture frame? 🏠 DebrisGuard is the ultimate handy companion for your power drill, specifically engineered to catch drywall dust, plaster, and debris right at the source before it hits your floors. 🎯
🚫 No more vacuuming after every single hole.
📐 Easy-to-use alignment helps you stay accurate.
🖨️ Print-in-place design requires absolutely zero supports.
⏱️ Fast slice-and-print settings get you back to your DIY project in no time.
Download, slice, and keep your workspace pristine! 🪚🌪️
