2026-04-01 21:33:12
48.1k
6.3k
Desiccant Box for AC(E)-X
@BamBamDesign_2075164
Desiccant Box for AC(E)-X & AC(E)-X Pro
The Filament Dry Box for Kobra
This desiccant container is special designed for my AC(E)-X Filament Boxes.
They fit perfectly under each spool and can be easily removed thanks to the small handle.
Each AC(E)X has space for two of these Desiccant Boxes.
The boxes feature a sliding lid that securely keeps the silica beads inside the container.
A bit more than 100g fits in each box.
I used this silica: https://amzn.to/4cFc3gA (Reflink)
Keep your filament dry for the best printing experience.
Moisture damages filament and decrease printability.
Dried filament behaves reliably and results in clean prints.
The AC(E)-X solution with these Desiccant Boxes helps enormously with this.
Check the AC(E)-X Basic Files: https://makeronline.com/en/model/282135
Also check this upgrade:
Hygrometer Lid to see instant the humidity in the boxes:
Happy Printing 😊👍
AC(E)-X Pro:
I carefully reviewed your feedback, tested new ideas, optimized countless details, and after many days of work and endless printing hours, the Pro Version is finally full optimized, tested, documented and ready for you to download. I will thank you for the support here! My Patreon subscribers will get exclusive early access to the model.
https://www.patreon.com/posts/156876582
Desiccant Box
silica gel
silica
beads
desiccant
ACE-X
AC(E)
Drybox
filament
moisture
keep dry
container
basket
ACE X PRO
