2026-09-21 01:29:12
404
11
Destroyer Tank
@Homedecor_3530134
My Patreon Join For Free ❤️ or for Commercial Rights
This highly detailed Tank Destroyer model is designed specifically for 3D printing, combining realistic proportions, functional design, and smooth assembly. The model features movable components and modular construction, allowing for both display and interactive handling.
The turret rotates smoothly, and the cannon can be elevated and positioned, providing dynamic posing options. The wheel assembly is designed for proper alignment and clean fit, ensuring a satisfying and precise assembly experience.
All parts are optimized for FDM and resin printing, with carefully engineered tolerances to ensure easy assembly without excessive post-processing. The model is divided into logical sections to minimize support requirements and improve print success rates.
This design is ideal for collectors, hobbyists, and enthusiasts looking for a professional-quality armored vehicle suitable for display, dioramas, or mechanical appreciation.
Key Features:
Easy and logical assemblyMovable turret and cannon elevation
Rotating wheels
Optimized for FDM and SLA/DLP printing
Clean tolerances for reliable fit
Highly detailed and realistic design
Minimal supports required
Suitable for scaling
Disclaimer
This model is intended for personal use and display purposes only. It does not represent a functional weapon and contains no operational capability.
Some minor sanding, fitting, or tolerance adjustment may be required depending on printer calibration, material, and slicer settings.
Recommended for users with basic 3D printing experience.
The designer is not responsible for print failures resulting from improper printer setup, incorrect slicer settings, or material limitations.
This file is provided as a digital product. Redistribution, resale, or sharing of the files without permission is prohibited.
tank
destroyer
vehicle
contest
wheels
light
toy
toys
decor
decoration
homedecor
assembly
exclusive
easy print
