2026-10-24 04:33:32
86
DoorSide – Reversible Over-Door Clothes Hanger Rack
@Trisztan_4700665
Create extra space for clothes on hangers with this one-piece over-door rack. Six circular openings keep individual hangers separated, while the open triangular frame supports the projecting arm with less material. The reversible design can be used on either side of a suitable door.
Print the single part, remove any brim and place the top hook over the door edge as shown in the photographs. No screws or assembly hardware are required. Measure your door thickness and check the clearance above it before printing. Check that the rack fits securely and the door can move freely.
Suggested FDM starting settings: 0.4 mm nozzle, PLA, 0.20 mm layers, 2 walls and 15% gyroid infill. Supports are not required in the supplied orientation; use a brim if needed. Adjust the settings for your printer and filament.
Allow the print to cool and inspect the hook and hanger openings before use. Load gradually; no rated load capacity has been established.
door hanger rack
over door holder
clothes hanger
laundry organizer
reversible rack
