Cable Wall Grommet – 18 mm Wall Thickness (Double-Sided)
This 3D printed double-sided cable grommet is designed to safely route a cable through thicker walls or panels, while protecting it on both sides of the surface. The two-piece design creates a clean and secure pass-through, eliminating sharp edges and reducing cable strain.
This version is intended for:
- Wall / panel thickness: 18 mm
- Required hole diameter: 10 mm
- Cable diameter: up to 7 mm
The grommet is installed from both sides of the wall, creating a firm, centered fit and a finished look on the front and back surfaces. Its smooth internal geometry ensures gentle cable routing and helps prevent abrasion or long-term damage.
Key features
- Double-sided design for thicker panels
- Protects the cable on both entry and exit points
- Clean and professional finish
- Easy press-fit installation
- Ideal for desks, furniture, walls, and DIY projects
This model is a practical solution for neat, safe, and durable cable management when working with thicker materials.
