Printing tips
- Do not simplify the model.
- Dont scale the Z-Axis, otherwise the color layers no longer fit. Apart from the Z-axis, the model can be scaled as desired
There are two models Cherry and Cherry 2, with the only difference being the colors used.
The Model is mm in size
There are the stl files and the 3mf for anycubic slicer
HueForge Print & Swap Description
Using a 0.4 Nozzle
IMPORTANT -> Print at 100% infill with a layer height of 0.08mm with a base layer of 0.16mm
Filaments Used:
- #000000 PLA Anycubic Black Transmission Distance: 0.8
- #ffffff PLA Anycubic White Transmission Distance: 11
This print uses 2 unique filaments
Swap Instructions:
- Start with Black
- At layer #13 (1.12mm) swap to White for the rest.
