2026-08-22 07:18:17
430
14
Drink Sleeve 330ml Slim
@Markt3D_4118638
🧊 FrostGrip Chiller – 330 ml Slim Cooling Drink Sleeve
⚡ The compact version, specially designed for 330 ml Slim cans!
The new FrostGrip Chiller 330 ml Slim has been specifically designed to fit 330 ml Slim cans with a precise and secure fit.
Smaller, more compact, and easier to handle than the standard version, it keeps your drink colder for longer thanks to its integrated cooling chamber.
The design has also been upgraded with a reinforced handle, providing a stronger grip and improved durability for everyday use.
Perfect for any situation: outdoors under the sun ☀️, at your office desk 💼, during gaming sessions 🎮, or simply relaxing at home.
💧 How to Fill the Cooling Chamber
You can use the FrostGrip Chiller in two ways:
1. 💧 Plain Water
The fastest and simplest method.
Fill the cooling chamber with water without any special preparation.
2. ❄️ DIY Cooling Gel – Recommended
For longer-lasting cooling performance, you can prepare a simple ice-pack style cooling gel.
Thanks to its thicker consistency, the gel stays cold for longer and helps reduce the risk of leaks.
🧪 Recipe for approximately 300 ml of water
  • 💧 300 ml of lukewarm water
  • 🧂 1 generous teaspoon of salt
  • 🥣 1/2 generous teaspoon of guar gum
🔄 Preparation
  1. Add the salt to the water and stir until completely dissolved.
  2. Slowly add the guar gum.
  3. Mix vigorously to prevent lumps from forming.
  4. Continue mixing until you obtain a smooth, uniform gel.
⚠️ IMPORTANT – Golden Rule for the Freezer!
NEVER FILL THE COOLING CHAMBER TO THE BRIM!
Fill the cooling chamber to approximately 85–90% of its capacity and always leave 10–15% empty space (air gap) before closing the cap.
When frozen, water and cooling gel expand in volume.
If the chamber is filled to 100%, the expansion of the frozen liquid can create significant pressure against the walls and damage or crack the 3D-printed component.
Leaving an air gap gives the liquid enough room to expand safely.
🥤 Compatibility
Specifically designed for 330 ml Slim cans.
The can compartment has been designed with a very tight tolerance, allowing the can to fit precisely and remain securely seated inside the FrostGrip Chiller.
🖨️ Designed for 3D printing
💪 Reinforced handle
❄️ Integrated cooling chamber
🥤 Compatible with 330 ml Slim cans
Drink
drink sleeve
energy
enerfy drink
monsters
kobra x
gaming
tool
tools
cup
bicchiere
