2026-08-08 05:50:27
3.4k
368
Drink Sleeve
@Markt3D_4118638
🧊 FrostGrip Chiller – Cooling Drink Holder
Tired of your favorite drink always getting warm? 🥵 Try the FrostGrip Chiller, a unique and modern cooling Drink Sleeve designed to keep your drinks cold for longer!
Its carefully designed cooling chamber provides excellent thermal performance, while the ergonomic handle makes it comfortable and secure to hold. Perfect for any occasion: outdoors under the sun ☀️, at your office desk 💼, or during your gaming sessions 🎮!
💧 How to Fill & Dosage
The FrostGrip Chiller can be used with two different cooling options:
1. Plain Water:
The fastest and easiest option, requiring no special preparation.
2. DIY Cooling Gel – Recommended for maximum performance! ❄️
Creates an ice-pack style thermal gel that holds the cold much longer. Thanks to its thicker consistency, it also helps minimize the risk of leaks.
🧪 Recipe for approximately 300 ml of water
  • 💧 300 ml of lukewarm water
  • 🧂 1 generous teaspoon of salt (helps lower the freezing temperature)
  • 🥣 1/2 generous teaspoon of guar gum (acts as a thickener to create the gel texture)
🔄 Instructions
First, stir the salt into the water until it is completely dissolved. Then slowly add the guar gum while mixing vigorously to prevent lumps from forming.
Continue mixing until the liquid becomes a smooth and uniform gel.
⚠️ WARNING: Golden Rule for the Freezer!
DO NOT FILL TO THE BRIM!
Fill the cooling chamber to approximately 85%–90% of its capacity and always leave 10%–15% empty space (air gap) at the top before closing the cap.
As liquids freeze, they expand in volume. If the chamber is filled to 100%, the pressure created by the expanding frozen liquid can damage or crack the 3D print.
Leaving an air gap gives the gel enough room to expand safely.
🔧 Product Update – August 22, 2026
A design improvement has been implemented on August 22, 2026.
The handle grip and support structure have been reinforced, increasing the overall support and improving the strength, stability, and durability of the handle during everyday use.
This update provides a more secure grip and improved resistance in the connection area between the handle and the main body of the FrostGrip Chiller.
Version updated: August 22, 2026
Modification: Reinforced handle support and improved grip strength.
Drink Sleeve
monster
energy
monster enerhy
cup
kobra x
