2024-09-17 12:07:55
9.1k
662
Dugtrio Keyboard Switch Tapper
@vkobz_1020444
The inevitable sequel to my Diglett Tapper - Dugtrio is here!
Bonus - you can print any of the angry Digletts to use in the original rock base for a new twist without using more keyboard switches. Or mix in a happy Diglett to your Dugtrio base!
PARTS:
You will need 3 keyboard switches in a cherry mx format or similar. The ALL PARTS .stl file contains all printed parts (3 sets of eyes, 3 noses, 1 head of each size, and 1 rock base). Or you can download each component type separately. You will not need multiples of each, since they are already in the proper quantities.
ASSEMBLY:
The eyes should be press fit, the noses may require glue.
Once the faces are assembled, push the keyboard switches into the base as shown in the photos, and pop the heads on like key caps.
PRINT SETTINGS:
**Ensure your bed is newly leveled, so the keycap stem does not get squished into the bed, causing fit issues. Elephant foot compensation can help too (I used 0.15mm).**
No supports needed.
Base - 3 walls, 10% infill, any layer height
Heads - 4 walls, 10% infill, adaptive layer height (0.12-0.24mm), outer walls first, 80mm/s outer wall speed, scarf joint seam if possible, brim optional
Eyes and noses - any walls/infill, add a brim with brim-object gap of ~0.18mm for easy removal
Please share your makes and feedback!
dugtrio
diglett
pokemon
tapper
fidget
clicky
keyboard switch
clicker
