This model features a screw mechanism that securely connects the dumbbell heads to the rod. The interior can be filled with sand or glass beads to customize the weight according to your needs.
- Screw Mechanism: Easily assemble the dumbbell heads and rod with a secure screw connection.
- Adjustable Weight: Fill the interior with sand or glass beads to achieve the desired weight.
- Child-Friendly Design: Ideal for encouraging children to engage in light physical activity.
- Customizable: Print in various colors and materials to suit your preferences.
非常适合儿童的轻运动训练。此模型采用螺旋机制,将哑铃头与哑铃杆牢固连接。内部可以填充沙子或玻璃珠,根据需要调整重量。
- 螺旋机制: 通过螺旋连接轻松组装哑铃头和哑铃杆。
- 可调节重量: 内部可以填充沙子或玻璃珠,以达到所需的重量。
- 儿童友好设计: 激励儿童参与轻体力活动的理想选择。
- 可定制: 可以打印成各种颜色和材料,以满足您的偏好。
