2026-10-08 23:44:05
2.2k
237
EMBT Gen 1 2018 European Main Battle Tank 1/35 Scale
@Bavaria_3DTanks_4611156
If you enjoy my work, consider supporting me ❤️ ❤️ ❤️
Buy Me a Coffee:
buymeacoffee.com/bavaria3
Ko-fi:
https://ko-fi.com/bavaria3
BoostI am an aerospace engineering student from Ottawa, Canada, and also a military enthusiast. Every model here is designed from the ground up by me in Fusion 360 and printed using my own equipment, with no AI involved. Each design is tested and refined repeatedly to ensure it is reliable and works as intended.
📋 Recommended Print Settings (For Best Results)
Filament: PLA. Different materials have different shrink rates, so using other filaments might cause fitting issues or dimensional errors during assembly. Ambient Temperature: If you’re using an open-frame printer like the A1 or A1 Mini, keep your room above 20°C (68°F) to prevent warping.
Print Bed Preparation: Wash with soap and water, then dry thoroughly to ensure good adhesion. For small parts, apply a glue stick for better bed adhesion.
🔧 Assembly Diagram Notes
Blue Lines: Require super glue for assembly. I use Gorilla Super Glue. Yellow Lines: These are moving parts. Do not apply glue here.
tank
military
war
warthunder
worldoftanks
PDF
Assembly Guide.pdf
192.33KB
