2024-12-24 17:38:53
3.5k
196
ESP-WROOM-32 ESP32 Case
@Gabriel_2651459
Case for ESP-WROOM-32 ESP32. The lid snaps on without any screws or glue and has openings for pressing the buttons with a paperclip. The base is deep enough to keep the headers on the board, although I de-soldered mine. There is an opening at the back of the case to let wires through for your project.
I also added a taller version of the case in case anyone is interested in using dupont connectors on the headers.
**11/22/2024: Version 2 and narrower version uploaded - Based on feedback in some of the comments, I made some changes to the original design. Basically, I made the standoffs attached to the walls of the case and eliminated the pins at the top, so it's possible to fit the USB C version in the case with the USB C connector that sticks out a bit from the PCB.
I also uploaded a narrower version of the case that fits different versions of the ESP32-WROOM-32 that does not have any holes for standoffs. This fits both micro-USB and USB C versions.
All parts print without supports. I recommend a .2 layer height and a .4 mm nozzle.
