2026-07-28 22:37:37
469
ESP32 WROOM 38-Pin Enclosure
@Karel_1613677
A clean, practical, and functional enclosure designed specifically for the ESP32 WROOM 38-pin development board. Perfect for prototyping and permanent DIY smart home projects.
-    Integrated Push Buttons: Easy access to the onboard EN (Reset) and BOOT buttons without needing a    stylus or pin.
-    Status LED Hole: Dedicated light-pipe/viewhole to easily monitor the status LED.
-    Exposed Bottom Pins: Full access to all 38 GPIO pins from underneath, making breadboard wiring and    jumper connections fast and hassle-free.
-    Durable Fastening: Four corner mounting holes designed for M3 x 8 mm screws/bolts to secure the    cover tightly.
Hardware Required
-    4× M3 x 8 mm socket head cap screws / bolts
esp32
esp 32
esú32 wroom
wroom 38
iot
case
esp32 case
microcontroller
diy
enclosure
