Introducing the Eco-Friendly Domino Rally, a delightful game that combines creativity, sustainability, and fun for the whole family! This unique set features specially designed parallelepiped blocks that create an exciting chain reaction when lined up in a row.
Crafted with ingenuity, each parallelepiped block is engineered to require minimal material, making it the perfect solution for recycling those small filament remnants found around the house. By repurposing these leftovers, not only do you reduce waste, but you also contribute to environmental conservation.
The Eco-Friendly Domino Rally provides an engaging activity for both children and adults, fostering creativity, problem-solving skills, and teamwork. As the first block falls, watch in awe as the rest follow suit in a mesmerizing cascade of movement and sound.
Designed with sustainability in mind, this game offers a playful way to teach the importance of recycling and environmental stewardship. Included in the files are accessories to help you build fabulous personalized courses:
- Pedestals of varying heights (10mm, 20mm, 30mm, 40mm, 50mm)
- Bridge, stairs, slide, and direction changer
Get creative with your course design by incorporating household items like books, toys, DVDs, cutlery, and more to add dynamic elements to your setup. Let your imagination run wild and turn everyday objects into part of the excitement!
Note: This file is intended for personal use only and may not be modified, redistributed, or used for commercial purposes.
