2026-08-05 06:36:48
395
Electric Beverage Dispenser - Easy to Assemble
@PRINTyourDREAM_3430558
The most practical dispenser on all of MakerWorld easy to print and assemble!
Bottle compatibility
The dispenser is DESIGNED TO HAVE an approximate diameter of 8cm and a height of approximately 30cm
PERFECT for 1.25L slim bottles
standard 1-liter soft drink bottles
✅ The entire setup can be assembled without welding.
🔧 Required components:
1. Electronic Parts
2.       Pipes
  • 1× Food grade silicone tube 2×4mm (air)
  • 1× Food grade silicone tube 6×8mm (drink)
3.       Optional
  • 3× 2-way connection terminals (if you don't want to solder)
⚡ Nutrition information
The air pump motor is designed for 6V DC it can be powered by a 9volt battery which will provide more power or by two 3volt batteries in their own compartment like my project
The higher voltage provides additional power, allowing the drink to be dispensed within a reasonable time.
This slight overvoltage has proven reliable in practice and does not damage the motor during intermittent use.
You can choose two different types of batteries to make this project!!!
  1. particular 3 volt battery
  2. OR
  3. A classic 9volt battery
dispenser
distributore
distributore di beva
bibite
drink
cocacola
coca
festa
bar
automatico
acqua
