Please Read
There are two seperate elephants you can print. Both are the same size except that the finger holes are different sizes. This allows for you to pick a starting place and scale the elephant either bigger or smaller to meet your finger size. Below is a link to finger sizing for rings that you can use as reference.
https://www.brilliance.com/ring-size-conversion-chart
The first elephant is size 5.5 in USA ring size with a hole of 16mm.
The second elephant is size ~10 in USA ring sizes with a hole of 20mm.
If you scale your elephant please be sure to scale the eyes and tusks as well. They have a built in tolerance of .5mm for the slots and will most likely need glue to secure them in place.
https://www.printables.com/model/697631-elephant-finger-puppet
