2026-05-14 02:31:14
678
9
Elf fishing pole
@PrinterInUse_1622794
The elves asked me to make them fishing poles.
string is “needed”. if you don't have string I'm sure you can use filament and heat it with a lighter to bend it
If you need the hole larger, I am more than happy to modify it for you. I made it for 2mm string, if you need the hole wider either ask me to modify for you or you can modify it in BambuStudio.
Steps: Right click on the model, select Add Negative Part and select Cylinder. In the top tool bar select Scale and change X and Y to the width of the string you need and change Z as needed.
elf
on
shelf
fishing
pole
