🍔 Ergonomic Burger Press (120mm) with Easy-Release Base
Tired of burgers sticking to the press or losing their shape when you try to get them out? This 3D-printed burger press features a smart 3-piece design with a removable bottom disc, making it incredibly easy to pop out perfect, uniform patties every single time.
With a 120mm diameter, it’s the ideal size for standard burger buns, ensuring your patties look professional and cook evenly.
🌟 Key Features
- Easy-Release Bottom Disc: No more digging the meat out. Just press, lift the outer ring (or push from the bottom hole), and your patty comes out flawlessly.
- Classic Grill Lines: The bottom disc features a textured pattern to give your patties those authentic ridges that help hold sauces and seasoning.
- Ergonomic Handle: Designed to fit comfortably in your hand, allowing you to apply even pressure without strain.
- Heavy-Duty Design: Reinforced with support ribs around the handle base to withstand firm pressing.
