2026-03-13 01:08:04
830
44
Event Horizon - Modern RGB LED Lamp
@Joshuasoddities_575101
"Every second that goes by, many people are born, and many people pass on. Every death leads to the moment after, a whole new beginning. All of us have a path of probability we are on; even if we never meet, our paths are not just connected, but intertwined. The world doesn't stop when we take that long nap, the cycle continues."
Welcome to Event Horizon.
Designed to represent the endless, intertwined cycle of life and time, the continuous twisted loop creates mesmerizing light diffusion that change beautifully depending on the angle you view it from.
REQUIRES A 3FT LED LIGHT ROPE
  • Zero Glue Required: The lamp and the base feature a threaded design. Simply screw the two pieces together for a secure, flush fit.
  • Simple Hardware: Designed to work perfectly with standard 3ft LED light tubes. No complicated wiring or soldering is required.
  • Material: For the best light diffusion, print the lamp body in White PLA, PETG, or PC. For the base, Matte Black or dark-colored filaments provide a great contrast.
  • Infill: 40% Gyroid infill is recommended for the base, solid walls on the lamp portion.
  • Wall Loops: 3 Walls
  • Supports: Organic supports (Painted on in the 3MF)
Assembly Instructions:
  1.   Insert your LED tube into the designated channel in the lamp body. For a 3ft cord, it will wrap around the core twice. It may be necessary to lubricate your tube for insertion.
  2.   Route the cable down through the hollow threaded neck.
  3.   Pass the cable through the base, and securely thread the lamp body into the base until tight.
  4.   Plug it in and enjoy the glow!
lamp
led
modern
light
easyprint
torus
geometry
modern art
