2025-10-21 04:51:25
1.5k
73
Eyeball Clicker
@vkobz_1020444
Set the spooky mood with an eyeball fidget toy! See the rest of my tappers here: https://makeronline.com/en/user/collectionDetail/d61f95fe-0059-4e60-adae-78471fa32a48/6658.html
PARTS:
You will need a mechanical keyboard switch (Box switches seem to work best, but any cherry style switch will do), or you can print one of these springs (but it will not click): https://makeronline.com/en/model/Spring%20for%20keyboard%20switch%20fidgets/181651.html
There are three printed parts - the white/sclera, the veins, and one iris (choose the human or cat pupil shape).
ASSEMBLY:
No glue required! Place the keyboard switch in the cavity of the veins, then push the iris onto the stem of the switch.* Line up the threads of the white and red parts and screw them together.
*if using printed spring, start by assembling the spring and iris, then push the spring into the veins.
PRINT SETTINGS:
Please be sure you clean and level the bed for this print! The tolerance on the switch stem is very tight, but I have tested it in many filaments and with different types of switches. The color change for the pupil is done by a layer height modifier. If you do not have an AMS, insert a pause where you want to switch to black.
Happy tapping =]
fidget
tapper
clicker
toy
keyboard switch
eyeball
eye
halloween
spooky
