2024-09-27 20:09:37
11.6k
908
FN BHP (Fabrique Nationale Browning Hi-Power) Replica/Historical Prop
@DrMussy_950260
Don't forget to "Click A Like" & check out my other Cool designs and Follow my Weekly dose of KooKoo uploads, PLZ leave a comment what you want next! Also dont forget to look at my other 800+ designs ;)
The Browning Hi-Power is a single-action, semi-automatic pistol available in the 9×19mm Parabellum and .40 S&W calibers. It was based on a design by American firearms inventor John Browning, and completed by Dieudonné Saive at FN Herstal. Browning died in 1926, several years before the design was finalized. FN Herstal named it the "High Power" in allusion to the 13-round magazine capacity, almost twice that of other designs at the time, such as the Luger or Colt M1911.
During World War II, Belgium was occupied by Nazi Germany and the FN factory was used by the Wehrmacht to build the pistols for their military, under the designation "9mm Pistole 640(b)".FN Herstal continued to build guns for the Allied forces by moving their production line to a John Inglis and Company plant in Canada, where the name was changed to "Hi Power". The name change was kept even after production returned to Belgium. The pistol is often referred to as an HP or BHP,and the terms P-35 and HP-35 are also used, based on the introduction of the pistol in 1935. Other names include GP (after the French term grande puissance) or BAP (Browning Automatic Pistol). The Hi-Power is one of the most widely used military pistols in history,[9] having been used by the armed forces of over 50 countries.Although most pistols were built in Belgium by FN Herstal, licensed and unlicensed copies were built around the world, in countries such as Argentina, Hungary, India, Bulgaria, and Israel.
After 82 years of continuous production, FN Herstal announced that the production of the Hi-Power would end, and it was discontinued in early 2018 by Browning Arms. From 2019 to 2022, with new Belgian Hi-Powers no longer being built, new clones were designed by various firearm companies to fill the void, including GİRSAN, TİSAŞ, and Springfield Armory, Inc. These new Hi-Power clones began competing with each other by offering new finishes, enhanced sights, redesigned hammers, beveled magazine wells, improved trigger, and increased magazine capacity.
In 2022, FN announced they would resume production of the Browning Hi-Power. The 2022 "FN High Power" incorporated a number of entirely new features such as a fully ambidextrous slide lock, simplified takedown method, enlarged ejection port, reversible magazine release, wider slide serrations, different colored finish offerings, and 17-round magazines. In contrast to popular belief, the new FN High Power might resemble a modern Hi-Power, but it is, in fact, a different design. One of the noticeable details is the lack of Browning-style locking lugs.
Support Is Required, NO Brim or Raft required, Quick and easy print less than 3hrs (frame)
Print Settings:
0.2mm layer
6 Walls/Shells
20% Infill
Material Used:
Anycubic PLA High Speed BLACK & GREEN
BOM: (Bill Of Material)
1.5 mm OD x 50mm L x music wire (Mag catch)
10 mm OD compression spring x 100mm L (slide)
6mm OD x 50mm L Rod (lower frame)
2 mm OD x 20 mm L Rod (Trigger)
5mm OD x 12mm L compression spring (behind the trigger)
10mm OD x 35mm L Rod (attaching the Suppressor or Compensator)
Mag catch spring:
https://www.amazon.de/Auto-Achse-lang-Durchmesser-Edelstahl-St%C3%BCck/dp/B00JR5BTXQ/ref=sr_1_6?
Recoil & Trigger Springs:
https://www.amazon.de/Verschiedene-Erweiterung-Aufbewahrungsbox-Handwerkzeuge-Ersatzteile/dp/B097PZT2CY/ref=sr_1_5?
Trigger Axle:
https://www.amazon.de/sourcing-map-Vollrundstab-Edelstahl-Heimwerker/dp/B083DXD9QT/ref=sr_1_10?
If you are interested in other prop firearms, Airsoft parts and designs do join our group on Matrix:
https://app.element.io/?pk_vid=f12152aac29bbc4a166549437941781a#/room/#GCI-General:matrix.org
!!!Note: I'm always open for suggestion and help on improving the design and proof of concept.
gun
pistol
prop
replica
training
historical
