Welcome! This is a complete, 3D-print-ready remix of the iconic Cupcake from Five Nights at Freddy's.
The original model had several geometry issues that made it completely unprintable. I have modified and rebuilt the structure to make it modular, functional, and easy to print.
🛠️ Key Improvements & Assembly:
- Two-Piece Modular Design: The top part (the frosting) and the bottom part (the wrapper) have been separated. This allows you to print them easily with minimal supports and snap or glue them together.
- Detachable Flame: The flame is a separate piece that fits perfectly onto the candle. This makes it super easy to print in a different filament color (like translucent, yellow, or glow-in-the-dark!) without needing an AMS or complex filament changes mid-print.
- 🕯️ Candle Assembly Options: Due to the geometry of the frosting, there is no pre-made hole. You have two great ways to attach the candle:
- The Quick Way: Simply glue the candle directly onto the flat center of the frosting.
- The Custom Fit Way (Recommended): Gently heat the center of the frosting and the bottom of the candle with a heat gun or lighter for a few seconds, then press the candle firmly into the softened plastic. It creates a perfect, realistic indentation!
⚙️ Recommended Print Settings:
- Supports: Only needed where strictly necessary (e.g., under the frosting overhangs).
- Infill: 10-15% (Gyroid works best to keep the prop lightweight yet sturdy).
- Layer Height: 0.16mm or 0.20mm for smooth details.
⚠️ Remix Note: This model is a substantial overhaul of an existing design, re-engineered to ensure optimal printing on Bambu Lab machines and standard FDM printers.
