2024-06-12 04:00:57
4.7k
308
Ferrari SF71H 2018 Formula 1 Car
@Sam_2602201
Printed at 0.12 (marked with a *) - 0.2mm (everything else) layer height and around 10% infill on all objects.
Supports will be required for the majority of objects (basically everything except the wheels and steering wheel). I found that organic tree supports worked the best in terms of removal and final finish. You may want to consider moving some of the parts down on the build plate to reduce the amount of supports needed (e.g. for the plank underneath the car).
The parts will require gluing once printed. I would recommend getting the body assembled first then carefully positioning the suspension and wheels to make sure it sits flat.
The parts you will require are:
1 x Part 1
1 x Part 2
1 x Part 3
2 x Front Suspension* (1 x regular, 1 x mirrored)
2 x Front Wheels
2 x Rear Suspension* (1 x regular, 1 x mirrored)
2 x Rear Wheels
1 x Front Wing*
1 x Halo* (either Halo_V2 or Halo_With_mirrors)
1 x Steering Wheel*
formula one
f1
car
race car
racecar
ferrari
car model
