2026-08-31 14:16:30
439
Fibonacci Lamp - Mathematics in Light
@Varulfen_5201733
Fibonacci Lamp – Mathematics in Light
My Fibonacci Lamp combines the beauty of mathematics with light and 3D printing. The lamp’s form is inspired by the Fibonacci sequence and phyllotaxis—the mathematical principle governing the arrangement of elements like leaves, seeds, and blossoms in nature. The individual components form a uniform, spiral structure that radiates outward from the center, giving the lamp its organic, almost flower-like appearance.
When switched off, the lamp’s extraordinary geometry takes center stage. When illuminated, light shines through the gaps and the semi-translucent material. This makes the many overlapping spirals stand out even more clearly, creating a dynamic pattern of light and shadow. The surface takes on a slightly different look depending on the viewing angle.
The curved stand echoes the spiral motif, extending the mathematical theme down to the base. The result is a decorative object where the Fibonacci sequence is not merely an invisible structural foundation but can be experienced directly through form and the interplay of light.
Designed for FDM 3D printing, the lamp consists of several parts that are assembled after printing. For the light source, a suitable LED strip should be used; I recommend a warm white strip (3500K), or alternatively, an adjustable or RGBW LED strip. The stand features an integrated cable channel, while the lampshade includes a channel designed for an 8mm LED strip, allowing for easy mounting with a retaining collar.
Deutsch:
Fibonacci Lampe – Mathematics in Light
Meine Fibonacci Lampe verbindet die Schönheit der Mathematik mit Licht und 3D-Druck. Die Form der Lampe ist von der Fibonacci-Folge und der Phyllotaxis inspiriert – jenem mathematischen Prinzip, nach dem sich beispielsweise Blätter, Samen und Blüten in der Natur anordnen. Die einzelnen Elemente bilden eine gleichmäßige, spiralförmige Struktur, die sich von der Mitte nach außen entwickelt und der Lampe ihre organische, fast blütenartige Erscheinung verleiht.
Im ausgeschalteten Zustand steht vor allem die außergewöhnliche Geometrie im Vordergrund. Wird die Lampe beleuchtet, scheint das Licht durch die Zwischenräume und das leicht lichtdurchlässige Material. Dadurch treten die vielen überlagerten Spiralen noch deutlicher hervor und erzeugen ein lebendiges Muster aus Licht und Schatten. Je nach Blickwinkel wirkt die Oberfläche immer wieder etwas anders.
Der geschwungene Standfuß greift die Spiralform erneut auf und führt das mathematische Thema bis in den Sockel weiter. So entsteht ein dekoratives Objekt, bei dem die Fibonacci-Folge nicht nur eine unsichtbare Grundlage der Konstruktion ist, sondern unmittelbar als Form und Lichtwirkung erlebt werden kann.
Die Lampe wurde für den FDM-3D-Druck entworfen und besteht aus mehreren Teilen, die nach dem Druck zusammengesetzt werden. Für den Leuchteinsatz sollte ausschließlich eine geeigneter LED-Stripe verwendet werden, ich empfehle ein Warm weißen mit 3500K, alternativ einen Einstellbaren oder auch RGBW-LED Stripe. Im Standfuß ist ein Kabelkanal vorgesehen, im Lampenschirm ein Kanal für ein 8mm LED Stripe für eine einfache Montage mit Kragen.
Lamp
Febunacci
phyllotaxis
Maths
LED
