2026-10-22 10:56:23
110
Fidget Twist Blaster
@Swampy3D_1925332
A chunky cartoon revolver with a twist fidget hidden in the barrel.
  • Chunky cartoon style: big barrel, fluted drum, hammer and trigger guard.
  • Twist fidget barrel: an 8-piece print-in-place spiral fidget, 30 mm wide × 70 mm long, that locks into the barrel.
  • No AMS needed: print the gun in one color and the fidget in another.
  • No supports needed on any part.
  • Easy assembly: the fidget’s back piece fits a matching pocket at the back of the barrel, use a small amount of super glue to hold in place.
  • Assembled size: about 172 × 52 × 143 mm (length × width × height).
What’s included
  • blaster right half
  • blaster left half
  • 4 alignment pins (3 × 3 × 9.6 mm)
Assembly
  1. Break the fidget loose: twist and pull the pieces back and forth until they slide freely.
  2. Press the 4 alignment pins into the holes in one gun half.
  3. Lay the fidget in the barrel of that half. Turn it until the back piece drops into the pocket at the back of the barrel.
  4. Put glue in the pocket only (CA gel works best).
  5. Glue the two halves together on the flat face, keeping glue away from the barrel opening.
  6. Let the glue set fully before twisting the fidget.
⚠️ Keep glue off the barrel walls and the other fidget pieces, or the fidget will lock up.
fidget
fidget twist
gun
toy
kids
kid
fun
expanding
revolver
cartoon
bang
no support
blaster
spiral
fidget toy
satisfying
596.20KB
