2026-08-30 21:49:50
571
31
Filament guide bracket
@gianlucaprato_762184
This upgrade replaces the original fixed support that often creates too tight an angle between the spool and the PTFE, causing kinks and filament breaks. The new bracket introduces a soft, raised guide that leads the filament towards the PTFE tube more linearly. The result is smoother feeding, less friction and a significant reduction in jams. The design is optimised to print quickly, with good strength and no need for extra hardware.
Filament smoother
Filament alignment
Filament support
Bowden system
Kobra X upgrade
PTFE guide
