2026-02-18 20:57:15
1.7k
20
Filament spool shelf with an actually-pretty bracket
@Manethon_Sega_3814903
Most spool racks work… but look like a honeycomb parking garage.
This one is strong, practical, and actually pretty: ornamental vines + leaves, with flowery end caps.
Includes 2 shelves + washers + 4 end caps. The washers are important — they add compression and help prevent layer separation when mounting.
Why you’ll like it
Artistic design (not another industrial grid)
20mm wall clearance (spools don’t rub the wall)
Fits 20mm / 23mm / 25.4mm (1") dowels (all in the same 3MF)
Load tested: 18× 1kg spools for 1+ year with no failures ✅
Technical specs
Filament used: ~630g total (2 shelves + washers + 4 end caps)
Material: PETG recommended
Mounting: 2× M5 wall screws per bracket
Wall clearance: 20mm
Print settings (0.4 nozzle)
Layer: 0.28mm
Walls: 4
Top/Bottom: 4 layers
Infill: 15% honeycomb
Material: PETG is recommended (especially for heavy loads)
Quick install
Print: 2 brackets + washers + 4 end caps
Mount brackets with 2× M5 screws each + use the washers
Insert dowel (20 / 23 / 25.4mm)
Add end caps 🌸
Load spools and admire your new filament shrine
Feedback
Show me your setup: how many spools, what colors, PETG or chaos? 😄
Disclaimer
Results depend on wall type/anchors, print quality, screws, and dowel strength. Use proper anchors and don’t mount into questionable walls unless you enjoy surprise gravity events.
Side note (yes, mandatory)
If you stumble upon one of my models and think, “Wow, this person needs a hobby… or a nap,” feel free to hit that like button. It’s the digital equivalent of a pat on the back. And if you’re feeling extra generous, you can buy me a coffee via my Ko-fi. Because let’s be real, those long nights of modeling don’t fuel themselves.
Thanks for coming to my TED Talk. 😌☕
bracket
Filament
shelf
spool shelf
ornamental
vine
floral
