2026-07-09 12:45:47
744
19
Filapartner E1 Hygrometer Holder V2
@BamBamDesign_2075164
Hygrometer Holder E1
A simple but efficient Mod for Filpartner E1 . This mounting clip designed to hold a rectangular hygrometer. It fits snugly between the silicone outlets of the Chitu E1 dry box, allowing for easy installation without modifications. Now you can always keep an eye on the humidity level inside the dry box.
This is the revised V2 version. It is more stable, and the slightly oval openings make it easier to install.
Simply insert the hygrometer into the clip, then slide it over the silicone ports from the inside of the dry box. Installation works best if you gently press against the ports from the outside while fitting the clip.
Once installed, it holds the hygrometer securely.
I recommend printing this part in ABS or another heat-resistant material to prevent warping when using the drying function of the dry box.
Chitu E1: https://www.chitusystems.com/products/filament-dryer?variant=46306781036780
Rectangular Hygromter Reflink: https://amzn.to/42YAocS
Happy Printing 👍
chitu fílament dryer
filaparter e1
hygrometer
chitu
filapartner
e1
hygrometer holder
mod
level
humidity
