2026-10-27 18:46:28
12
First Layer Test – Full Bed
@Bnis_1720601
Check your entire build plate with the First Layer Test – Full Bed!
This practical calibration model is designed to help you evaluate first-layer consistency across a larger area of your 3D printer's build plate.
By testing multiple areas across the bed, you can identify uneven extrusion, adhesion problems, and potential bed leveling or Z-offset issues before starting larger prints.
  • Distributed first-layer calibration pattern
  • Tests multiple areas across the build plate
  • Helps identify uneven bed leveling and adhesion
  • Easy to inspect and compare different regions
  • Low filament consumption compared to a fully filled bed
  • No supports required
  • Suitable for FDM 3D printers
Recommended Print Settings
  • Nozzle: 0.4 mm
  • Layer Height: 0.20 mm
  • Material: PLA or PETG
  • First Layer Speed: 20–30 mm/s
  • Supports: Disabled
  • Raft: Disabled
  • Ironing: Disabled
How to Read the Results
Perfect First Layer: Smooth, consistent surfaces with well-connected extrusion lines across all test areas.
Gaps Between Lines: May indicate insufficient first-layer squish or under-extrusion.
Rough or Raised Surfaces: May indicate excessive first-layer squish or over-extrusion.
Poor Adhesion in Specific Areas: Check bed cleanliness, bed leveling, Z-offset, and temperature.
Different Results Across the Bed: May indicate an uneven build surface, bed mesh compensation issues, or inconsistent first-layer settings.
Why Use This Test?
A reliable first layer across the entire build plate is especially important when printing large objects or multiple models at once.
The First Layer Test – Full Bed helps you identify potential problems before wasting time and filament on larger prints.
Part of the ModuSlide First Layer Calibration Series.
Designed by ModuSlide
Happy printing!
first layer
full bed test
bed leveling
bed calibration
3d printer calibrati
z offset
