2026-05-14 03:18:45
743
20
Fixed Blade 1
@PrinterInUse_1622794
Knife Two! no folding here just a good old fixed blade using a standard box cutter blade.
another one inspired by the awesome designs @maker209  put out. be sure to check theirs out!
Hardware Requirements:
You’ll need 9 total machine screws, either 3x4mm or 3x5mm, depending on your preference:
  • 3 screws for the case
  • 3x4 or 5mm machine screws
  • 6 screws for the handle / scales you have a choice….
  • I used 3x4 machine screws so it looks nice. there is also ones that do not have a chamfer so you can use hex cap screws if you hate things looking nice and feeling smooth.
  • 3 more 3x5mm screw for the clip
About the Clip (full transparency):
Quick heads up… I’m pretty bad at making clips….This one’s a little rough around the edges, but it works!! I’ll clean it up and update it sooner or later.
The clip uses:
  • Three 3x5 hex screws
fixed
blade
knife
