2025-09-17 18:55:35
916
64
Flow Pot
@User_536_419079
Flow Pot
Functional, sleek plater
Printing recommendations & Assembly
I Highly suggest PETG or ASA if your print will be outside(Note: direct contact with soil is not ideal, as it may block the drainage holes—unless you place a small filter above them.)
Alternatively, Matte PLA with fuzzy skin(Process>others>Special mode>fuzzy skin>Contour) can give your print a more professional finish.
The planter is made of two parts:
  • The pot
  • The water reservoir base (mandatory)
Assembly is super simple—just stack the pot on top of the base. They align perfectly.
Scaling & Dimensions
If you need the the planter for small plants or bigger plant you can adjust the scale of the models from 33% to 150%. I don't recommend going beyond this range, as the water hole may become too large or too small.
📸 Images shown are from a print scaled to 85%, using Anycubic black PETG.
‼️IF YOU NEED A BIGGER VERISON PLEASE LET ME KNOW IN THE COMMENT‼️
Standard dimensions:
  • Pot: External 80×80×82.5 mm / Internal 74×74×77 mm
  • Base: External 80×80×13.4 mm
  • Combined: 80×80×87 mm
For any question or suggestions feel free to leave a comment or send me an e-mail at:📧 [email protected]
planter
pot
plant
grass
wavy
textured
squared
spiral
organic
vase
flowerpot
home
modern
minimal
simple
abstarct
artistic
interior
exterior
desk
