2025-06-27 23:52:07
2.6k
142
Flower Coaster Set
@Antek_3218687
The flower-shaped coaster project is not only a practical solution, but also an eye-catching decoration that brings a touch of summer atmosphere into your interior. Each coaster consists of segments forming flexible petals, which not only effectively protect your table surface but also delight with their appearance. After use, the coaster can be easily placed on a special stem that serves as a stand—the whole set then looks like a bouquet of flowers in a pot, evoking sunny summer days and the ambiance of a garden in full bloom. This practical and decorative solution will remind you every day of the joy and lightness of summer. No multi-color printing system is required, which further simplifies the project.
The segmented flower model is printed as a single piece, with only the stand requiring simple assembly. The optimal arrangement of leaves on the stem and flowers in the pot is shown in the photos below. Elements printed with a brim should first be carefully cleaned of any unwanted fragments. The stems should have edges prepared so that the leaves can be easily slid onto them. The thread in the pot must also be cleen. The flowerpot has a special compartment where you can hide something or, if necessary, add weight to the pot.
Version with magnets here: https://www.makeronline.com/en/model/Flower%20Coaster%20Set%20(magnet%20version)/187603.html
Assembling:
put center on the base and rotate couple of times to make it push smooth
Stalk and leafs:
Connect stalk and base
The stems should have edges prepared so that the leaves can be easily slid onto them. Every leaf and stalk have one flat side, so put them in same way
The optimal arrangement:
coaster
coffee
flowers
flower
summer
homedecor
ornament
gift
flexible
articulated
segmented
kitchen
