2025-08-09 10:54:37
1.9k
71
Foldable fruit platter(折叠水果盘)
@User_5991332
这是一款可以折叠收纳的水果盘,请开始打印模型文件之前,务必进行模型文件测试(测试文件在第三盘)并清洗整个打印面板
如果测试文件打印后无法活动,需自行对切片参数中孔洞补偿进行调整,每次调整值建议为0.1
如下图所示,调整后切片重新进行测试,如果还是无法活动,则继续调整切片参数
This is a fruit tray that can be folded and stored. Before starting to print the model file, be sure to conduct a model file test (the test file is on the third tray) and clean the entire printing panel
If the test file cannot be moved after printing, it is necessary to adjust the hole compensation in the slicing parameters by yourself. The recommended adjustment value for each adjustment is 0.1
As shown in the following figure, adjust the slice and retest it. If it still cannot move, continue to adjust the slice parameters
